Hi all!
the bike is a Hypermotard 939SP 2016.
Changed the front sprocket one tooth down, and disassembled the Footpegs bracket ( two allen screws 12 head and one 24mm socket at the top).
sprocket installed and entered all the screws. Tried to tighten sprocket with 186nm. While doing this the shaft turned a little. Had to wait for a friend of mine to hold the bike and pull the backbrake.
It stood on the sidestand over night.
Today I disassembled the footpeg again to get the socket (32mm) on the front sprocket for tightening. Then all of a sudden gear oil starts to pour from the threaded hole that goes in the engine block. Figured out I missed a washer from yesterday, and it is possible that I switched the 20mm long screw with the 30mm one. But I’m serious, when I assembled it all every screw went in smooth as butter and felt natural. I cannot imagine that i «bored» through the engine block or a seal of some type as i felt no resisting.
Is it possible that I have ruined something here? If so, I have some solutions.
For me its crazy that its even possible to do this. Call me stupid or whatever. I just need an answer..
when inserting the screw with washer it stops pouring. Haven’t tried driving it yet.
Also worth mentioning, I have a mechanical background, and this is not my first bike. Shall I plug the threaded hole or is it supposed to be like this? The hole oil is pouring from is where the item 24 (le
looking forward to all your answers. And sorry for my bad english...
regards
Frans
regards
Frans
