Does anyone know off hand the torque for the drain bolt? It is a different head size than my S2R and my late great ST3s, so I don't want to over/under tighten it.
thanks!
Bill was their a separate mesh screen that has to be removed like on the older ducs?Thanks Chris... yep went over to the 1098 forum...
http://www.ducatispot.com/forums/showthread.php?t=9549&highlight=oil+drain+plug
I do not like that little allen bolt.
18-22 ft pd, I went to 20 per post.
Which pin did you order? One for 1098? Does it fir both sides?Also had to order a bigger pin for my pit bull. That rear axle is HUGE!
Two different pin sizes one for left side and one for right. I ordered the pitbull reversible rear stand which comes with both size pins to enable placement on the left or right side. The pins are the same size as the STANDARD 1098 (NOT 1098R model!)/ I've several pitbull stands and are exc.Which pin did you order? One for 1098? Does it fir both sides?
Yes as Chris said... one side (left I believe) is 41mm, right is 43. I only have one pit bull stand set, I just swap pins. Need to get me a pair of sport chocks!
Chris do you know what pin for the front steering stem size is. Every chart is see say "special" but no pin / adapter#.
I've found a second listing of the oil filler plug.Thanks Chris... yep went over to the 1098 forum...
FYI - First 12 months of maintenance is free. 600 mile service and 7500 mile or 12 months whichever comes first. I usually do my own but if its free I'll let them take care of it.Does anyone know off hand the torque for the drain bolt? It is a different head size than my S2R and my late great ST3s, so I don't want to over/under tighten it.
thanks!
That would be a hard toss up. If I could spend 8 hrs on my bike, I just might have to do itNo dealer by me. So it's 10 minutes to do myself or 8 hours to make the round trip to the dealer.
It was posted before - this will not work for your Streetfighter. Program is only for '08 and '09 models, SF is 2010. I've got an e-mail response about this from DNA.FYI - First 12 months of maintenance is free. 600 mile service and 7500 mile or 12 months whichever comes first. I usually do my own but if its free I'll let them take care of it.
http://www.ducati.com/od/ducatinorthamerica/news/detail.jhtml?newsId=28681
That would be a hard toss up. If I could spend 8 hrs on my bike, I just might have to do it.
I'm lucky only to live 30 miles from my dealer. I could care less about them performing the 600 mile maitenance but the 7500 is different. I adjusted the belts/valves on my Duc 695 Monster. It was a pretty simple task especially since I had never adjusted valves before. I had software for resetting the TPS and adjusting idle. But to be honest I'm not so sure I could adjust the valves on the SF. Not stating that from a technical standpoint but from a time consuming standpoint.
I will put the first 500 mile day on it next weekend, should be a fun day!
sales guy told me that my 600 mi and 7500 mi maintenance visits were free...Only 08 and 09 bikes covered by this program, sf is a 10
Chris
What is official -all service in first year is free? Was there some dealer bulletin about it? If so, can you point me to it, so I can use this at my next dealership visit?the first year is free if you bought the bike after the recalls and delays.. Most dealers will give you the first service free, but now it's official (assuming you ride it enough in the first year).. and IF you can get 7500 miles on the bike in a year,, then you get the second one free as well. .. at least that's all the way my dealer explained it to me.
