1 - 7 of 7 Posts
I'm wanting to change the oil/filter and assume that the hexplug at the very bottom of the block is the drain. I don't have a maintenance manual yet so I'm guessing. Can someone guide me.
Thanks, Dan
That is it. Here is a picture. Be sure not to over torque (42NM). They are easy to strip.
Hope this helps.
Dan sounds like you got the right bolt. Pick up a new crush washer for the drain bolt.
FYI: they're about 50 cents (US) at my DUC dealer...
Same for the crush washer for the filter screen bolt
1 - 7 of 7 Posts
