I read a lot of posts and this is what I gathered. I have a 06 sc 1000 which has the dry clutch
*engine oil*
Mobil 1 full synthetic 10w40. What I wondered is can I use the big jug at Walmart that is like $24 for 5qt? It says 'high mileage' motorcycle. The bike has a dry clutch so not sure why I would need to consider motorcycle oil which typically is for wet clutch apps.
*Brake*
ATE sl and super blue. Seems the blue is higher rated but I hear they are different colors so I can tell when I have fully flushed right? Other than that, I can't see reason in switching between types?
*clutch*
Not sure.
So I searched Cycle Gear, Escondido Cycle Center and North County Yamaha and none of them carry ATE fluid. They did have the RBF600. So if I gotta order online other than say motorcycle superstore and the like, any recommendations?
Thanks
*engine oil*
*Brake*
*clutch*
Not sure.
Thanks
