The stock rear Ohlins spring on our Hyper "S" is a 01092-29 which by the Ohlins spring chart is a 6.7" long spring, the (1092). The (29) is the spring rate which is 514 lbs in. The next heavier springs are the 01092-(31) at 542 lbs in. & the 01092-(34) is a 571 lbs in.
The question I have is what is the rider weight range of each spring? I tried to find out the info, with NO luck, does anyone know? TIA Alex
