Stopped for a break yesterday after 100km and noticed smoke coming from the vertical cylinder exhaust. After a closer inspection oil was leaking from connection point of the remote preload hose on top of the shock.
Checked the nut and all tight. wound the adjuster right off to try and relieve pressure so reduce leakage. Once home the puddle under the bike grew quite large!!
I can fix the connection but how do i repolace the oil?? And what type of oil?? Will I have to send it to a shock specialist or can I fix this myself.......Anyone seen this before??
