1561 - 1580 of 1614 Posts
Actually, not looking good:
Unfortunately our stocked item was sold prior to your on-line order coming in.
I am currently awaiting confirmation from our supplier that this part is still available. It is no longer listed on their website.
If it is no longer available your order will be cancelled and full payment refunded.
I took a lathe to the throttle tube today so I can install some heated trips. Turned out pretty well (I'd already done some trimming with pliers and a bench grinder in the first pic). I still ended up trimming some rubber off the end of the grip (Koso Apollo grips) and I'm not real happy with the final appearance, but it'll be Fine.
976120
976121
Also, last week I went through and cleaned up all the connections between the battery, solenoid, starter, and ground: disconnected, cleaned with fine sand paper and steel wool, reassembled with a little bit of dielectric grease. I had one 68° day where I gave up trying to start it after 3 attempts; this morning it started right up at 45°. I also changed the oil back to 10W-40 (previous owner ran 20W-50). Both have contributed to much faster starting. I may still go with the motolectric.com cables, but a little maintenance made that less urgent.
So take one old school hyper, go exploring for 231 miles in West Texas, and what do a find? A swap where there used to be desert! Great ride and the Rio Grande rages! For those of you snow bound! Come to West Texas and ride the mountain trail. We were so close to Mexico I literally spit on it! By the way no wall, and bandits abound so 200 rounds of 9mm is a new riding equipment! Lol seriously dont ride here at night!
Sent from my SM-N960U using Tapatalk
1st Gen Hypermotard Hooligan
Discussion Starter #1,570
Looks like you're having fun exploring! :)
That's Mexico across the water, and then Mexico invaded! Guess we need a detour!
... and the cartels waiting just out of sight over that southern ridge ... some joker with a .50 cal sniper rifle had you in the crosshairs as you snapped the pic ....
:oops:
(I live in Yuma Az btw, I can see the border if I stand up in the bed of my pickup truck in my driveway and look south).
With a little common sense you are alright here. Again you dont do this road at night. The mountain road section is safe, it's far enough in land. You pick up the Mountain trail in Van Horn, Texas.
Guys I need a huge favor. Can someone with an 1100S (non-evo) take a pic of a fork leg and measure the length of the outer tube? This would be for marzocchis. I need a new leg for an evo SP and it looks like they are interchangeable.
Mexican Ducatista
Taken from my 2008 1100s:
977838
977839
I can measure my regular 1100 (non-Evo or S) if it helps ?
My question; is it possible to remove vertical belt cover on 1100 without removing fairings etc ? I have removed them only when fairings, tank etc. was disassembled and I remember it was pretty stiff to remove even then.
