As far as I know the only difference is the diameter of the idle air hose connector. The MWR lid will fit all versions of the OG Hyper.
I am hoping to take to the one I can buy (796 etc) and modify it for fitment, while leaving my stock one untouched. So I will need the bottom of the other air boxes to fit my bike (2011 evo SP).As far as I know the only difference is the diameter of the idle air hose connector. The MWR lid will fit all versions of the OG Hyper.
As far as I know they are the same. You can also modify your original one, as the "DP part" is just the lid which you can transfer easily to the replacement airbox. That is at least how I did it.Another one for the brains trust.. does anyone know if the airbox changed between the early 1100 and the 1100 evo/SP? Is the 796 airbox the same as the 1100 evo/SP?
The reason I ask is I am looking at a MWR airbox lid and would like to do the cutting for the mod before pulling mine out, there’s a few older 1100 and 796 ones available. It would also mean I can keep my stock DP one unmolested.
Nice, thanks for the info and good to hear you enjoy it.As far as I know they are the same. You can also modify your original one, as the "DP part" is just the lid which you can transfer easily to the replacement airbox. That is at least how I did it.
The MWR lid is great btw! The intake noise is glorious and you get a good bump in power and torque (in case you need any more).
Just make sure to clean the filter every year; I just pulled the tank for my annual service and checks, and the filter definitively needs a good cleaning and re-oiling after 4500 km.
Unfortunately not.I don’t suppose you have or know of any videos of how it sounds?
Yes, that is the DP slipper pressure plate. I installed the same clutch on mine.After living with regret after selling my Hyper 1100 Evo, I decided to do something about it. I just picked this up, a 2011 Evo SP with only 11,000kms and in great shape. I gave a 950SP a try, but it didn’t excite me like the 1100 did.
Can anyone confirm if this is a DP slipper clutch? I noticed some slight lever feedback on downshifts, which according to google can be attributed to a slipper clutch. Pulled the cover off and found this:
Here she is:
Thanks for that. Seems to work fine, and not cheap from what I've read. A nice score!Yes, that is the DP slipper pressure plate. I installed the same clutch on mine.
A very slim chance for it to completely shatter, the plastic wraps around the metal part completely.Is it somewhat inevitable this thing is gonna give way or is it just a slim chance?
I’ve just ordered one of these to fix the problem, they cost 40 Euro plus shipping. Contact star ace through FB if you want one. I figure I don’t want to risk it breaking, plus it looks better!Question: I've noticed some cracking on the throttle cam/pulley and people here have mentioned upgrading to a carbon or metal one cos Ducati doesn't sell replacements only the whole assembly.
The guy at the dealer says it's not really an issue since there's a metal part inside.
While I was at the shop the young lady thought my scary face was "cute" and took a pic for their IG
Here is another alternative.
Thanks for the help... looking at the pic from Starace it looks like the inner metal piece also holds the end of the cable so the failure point is the guide for the cable on the outer edge of the pulley. I'll keep an eye on mine for now, they're just tiny hairline cracks.I’ve just ordered one of these to fix the problem, they cost 40 Euro plus shipping. Contact star ace through FB if you want one. I figure I don’t want to risk it breaking, plus it looks better!
Nice looking piece...but I wouldn't trust my life to anything that guy makes.Mine was showing signs of cracking so replaced it with the StarAce version, works well and looks neater in to the bargain. View attachment 1062326
Whys that?Nice looking piece...but I wouldn't trust my life to anything that guy makes.
