Why? Are you having a problem with knocking?Hey guys, is it ok to use Lucas Moto Octane booster? I tried a bottle and it does seem to make the bike slightly faster. I was just wondering if it was ok before I order a bunch at bulk rate.
Thanks!
Ok, that's great info. Thanks for saving me the hassle and cash. Im not having any issues with the way its running, or any knocking. It was probably in my head that it made it faster!lol... my thoughts exactly
"Lucas Octane Booster - A Real Octane Booster! Tested and proven to deliver three times more boost than most other brands. Lucas Octane Booster is a GENUINE Performance Enhancer! It's safe for turbos, oxygen sensors and catalytic converters. Stops knocks, and raises MPG in high compression engines."
I think the misconception is thinking "boost" is = to a turbo, instead of simply additive (like ethanol) that allows you to run a higher compression (the part that makes more power) without detonating the motor to death. Literally changing your underwear has a greater chance of making your bike faster that that product, likewise for many "race fuels" . If the compression ratio is stock you have less than 10:1 and you could use some compression to need 87 octane.
If it is helping you might be better of trying some fuel system cleaners.
You typically use an octane booster to achiever a higher octane out of lower grade gas. IE: in my area of California 91 is all I can get, my Multi will run fine on 91, but it suggests 93 octane in the owners manual. If I wanted to run 93 octane I would get a tank of 91 and use an octane booster to raise my octane by 2. That's not necessary, but it is an option. To much octane and you get pinging to little and you get knocking (I may have the backwards, I always get if confused). If you go waaaay off your required octane rating you can get pre and post detonations which is a good way to grenade your motor.Ok, that's great info. Thanks for saving me the hassle and cash. Im not having any issues with the way its running, or any knocking. It was probably in my head that it made it faster!
I think you will find your manual lists the fuel as RON which is NOT what is on our pumps in the USA, given that California is only partially in. the stock 1000/1100 runs on 87 all day long and will often make more power as lobng as the hi test has not carboned the motor too much first.it suggests 93 octane in the owners manual.
Yeah, I've got a 2015 1200. The RON is a good point, like I said I don't use any boosters. I have found in CA that Stabil is a godsend though. I have had fuel go bad in 2 weeks to the point I had to drain the tank and clean the carb. Ethanol is rough stuff.I think you will find your manual lists the fuel as RON which is NOT what is on our pumps in the USA, given that California is only partially in. the stock 1000/1100 runs on 87 all day long and will often make more power as lobng as the hi test has not carboned the motor too much first.
What is in this stuff? Is it ethanol? Does it actually raise the octane level? Im just curious...I wont use it and thanks again!lol... my thoughts exactly
Thanks Fred...good info for sure!To learn more about octane, go to sunocoracefuels.com, go to tech corner, read "beyond octane".
They should know.....
Fred
Thanks ducvet! I am gaining a better understanding now. My friend who uses it has a limited race edition 2007 R1 (rare). He has had some work done to it and is running HP over 200 (according to him?).It appears it is mostly stuff that does not burn as you would expect from something that's job it is to prevent detonation.
This is why fuel that is free from additives often makes more power than fuel that is doctored with additives as the power potential is less when you have less combustible material in the first place. If it was 100% combustible you would in theory have less un-burned by product which you would think would be a cleaner fuel.
Now if you NEED a higher octane due to high compression or poor head design then you have no choice. Each design will have its limits based on a desired reasonable power (oem) and then the desired/modified reasonable limit of the owner and then the often unreasonable / heavily modified limits that live on the edge of destruction where racers live.
Honest question - how can it act like it does without actually doing it? If it lessens the tendacy to knock, it has increased the octane rating of the gas.Ive read up but Im still wondering...does this stuff actually increase the octane or just act like it does?
Thanks DesmoDog, that makes sense.Honest question - how can it act like it does without actually doing it? If it lessens the tendacy to knock, it has increased the octane rating of the gas.
