The most reliable and best value in slave cylinders on the market today.
OBERON Clutch Slave Cylinder: Ducati
Pricing: $153.00 * FREE Shipping
Oberon Performance clutch slave cylinder has proven to be the most reliable slave cylinder on the market. Designed to improve the performance and looks of the original Ducati cylinder. Substantially reducing the heaviness of the original clutch action, aching arms and clunky gear changes are a thing of the past.
The internal piston design, seals and breather hole have been drastically enhanced to stop leaks and leave a smoother clutch action. CNC machined from billet for lightness, strength and precision looks. The 29mm piston size is much easier to find neutral while still having an easy clutch pull. Everything you need is included in the kit plus a conversion shaft for earlier Ducati's.
UPDATE: Oberon has updated the slave cylinders to work with the 2011/2012 and newer bikes that have a pin to stop the rod from spinning. You won't need to remove the pin, there is now a recess built into the Oberon slave cylinder.
◾Smoother transition resulting in lighter clutch action
◾Available in six anodized colors
◾Black, Blue, Gold, Red, Silver and Titanium
◾CNC machined from billet aluminum
◾Repositioned breather hole away from chain and sprocket grime
◾'U' seals for precision action
◾Wiper seal to stop dirt ingress
◾Shaft and dust sealed back
◾Pre-2000 conversion spacer included
◾Simple to install
◾Stainless steel fasteners
◾Lifetime warranty
*Add MOTUL RBF600 Racing Brake Fluid as an option when purchasing this Oberon Slave Cylinder for only $16 ($21 value). Flush your brakes and clutch fluid at the same time.
*To insure longevity of your slave cylinder seals, start with a new throw out bearing and change your throw out bearing when you swap out clutch plates. Seized throw-out bearings are the number one cause of slave cylinder seal failures.
Clutch throw-out bearing
$3.95 *
Top quality bearings match OEM specificationsAll bearing are sealed both sides except as noted
Bearings are listed with the industry standard number as well as by dimension to use in various applications
All applications are for the innermost positions in the hub itself, unless noted
  • INCLUDED ITEMS:
  • One 6201-2RS bearing
  • BEARING DIMENSIONS:
  • Inside Diameter: 12mm/.472 in.
  • Outside Diameter: 32mm/1.26 in.
  • Width: 10mm/.394 in.
  • Seals: both sides sealed
OBERON Clutch Slave Cylinder: Ducati 1299 / 1199 / 899 /959 Panigale
The Oberon Performance Ducati Panigale 1199-1299 / 899-959 clutch slave cylinder has been designed to improve the efficiency and the looks of the original clutch slave cylinder unit. The internal piston design and seals have been drastically re-engineered to prevent leaks, piston jamming when hot and leave a smoother (judder free) clutch action. CNC machined from T6 billet alloy for lightness, strength and eye-catching good looks. Everything you need is included in the kit including full instructions and is ready to fit.
Our piston seals are manufactured from special Viton rubber which is frozen and then CNC machined with a 'U' profile (not standard 'O' rings) which is specifically for hydraulic use.
Weight: 104g
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or upgrade to lifetime VIP passwords for the deepest discounts on ALL products.
Look for memberships and choose the membership type that fits you the best
* Outside continental USA, use shipping codes:
