I initially thought, after replacing my master, line and slave, that something in the clutch system. I was having a hard time getting it into gear after a test ride.
https://www.ducati.ms/forums/57-supersport/714411-yoyodyne-issue-other-clutch-problem.html
Now, I've got it on the bench and as I started checking things out I noticed it's not going through the gears :frown2:
Here's a video of how things look,
Seems like it only goes into one gear, through neutral and into another. I have it set up in "Race" pattern so don't let the direction of the up/down shifts throw you off.
I have tried with the clutch lever depressed, clutch lever out. I can feel the trans in gear (not sure what gear it is) but it clearly is not stepping through all the gears.
Guessing my first step would be to check the gear selector fork return spring. Other ideas?
Jeff
Jeff
