1 - 3 of 3 Posts
I have a 2007 S2R 1000. I replaced the slave cylinder w Oberon and a new clutch line.
I can't get fluid to move out of the resevoir into the new line, even with a mitty vac.
I have tried using the slave bleeder w extras crush washers for shims on the master and use a vac.
The new slave is removed and filled w fluid by syringe. I will use a syringe next, to fill the new line. I left the new line disconnected and couldn't even get gravity to drain from the resevoir. Pumping clutch, using vac results nothing.
I have read about leaning the bike to dislodge air. The info does not make sense to lean bike to the right. This would help trap air near the lever instead of geting air to move out of master. Getting the exit of the master higher, by leaning bike to the left makes more sense.
Very frustrated.
Thanks for any ideas.
I left the new line disconnected and couldn't even get gravity to drain from the resevoir....
....Thanks for any ideas.
checking just the line for a blockage?
1 - 3 of 3 Posts
