  • Hey Everyone! Vote for the Site Favourite BOTM winner for the year of 2021 HERE!
1 - 19 of 19 Posts
Just got my first ducati. So I'm new to the Forum. It's a 2008 hypermotard 1100s that just rolled 8000 miles. I prefer to do all service myself so I went over the bike and replaced all the basics. Air filter. Spark plugs. Chain and sprockets. Tires. Both timing belts. Battery. Ect. I was doing a routine oil change when I noticed small nickle sized bits of metal magnetized to the drain plug. Any suggestions to what these might be? Shes benched until I have a better idea of what I'm dealing with. I attached a picture. Thanks all!
Wood Grey Beige Font Pattern
Agreed
I'm assuming it's magnetic & very hard.....Can you put a dent in it with a pair of ***** you know side cutter pliers? If you can't put a good mark in it that's definatly hardend spring steel from your shift spring
I was able to make a small mark about half way around the ring. More of a scratch than anything. And yes. It is magnetic. What could cause a catastrophic failure like that? Didnt seem to affect shifting at all. I was worried it was a piston circlip. I'll crack open the clutch housing tonight and see if I can find the culprit. Much appreciated.
Gold Amber Wood Flooring Floor
It's an early design flaw perpetuated in every Ducati that uses it....you want to remove the other side cover... opposite of clutch basket...
Nice thing is you don’t have to split the cases! New gasket and a spring will get you rolling again!
Screw the gasket use yamabond #4 hylamar sealer
Or if your feeling rich buy Ducabond (it's the same shit just expensive)
Reactions: DarrellF
Yamabond is pretty awesome. Used it on a jetski motor I rebuilt. Used my vacuum tester to make sure it held pressure and forgot about it for a few hours. Held pressure like no-bodies business.
I use the ThreeBond that is the exact same thing as DucatiBond, ---The number is TB1215
Reactions: chris_f
All the above work perfectly & the best part is when you take it apart next time.....and you will it cleans off with a rag & lacquer thinner in minuites NO MORE RAZOR BLADE NICKS just apply liberally to a clean cotton cloth lay it on your gasket surface & leave it for 10 or so minutes then wipe repeat as necessary.
BTW it works absolutly great on pipe threads and a hellovalot better than Teflon tape
This should have been a recall...it's painfully obvious that the spring will rub itself in half...any bike with the old style spring is vulnerable...
What are the symptoms of this spring being broken (other than finding parts of it) - OP states that the bike seemed to run and shift fine.
What years of bike had this design spring - would by 2010 848 likely have it?
Not terribly concerned - it seems to shift fine, and haven't found any pieces in any oil change (or when I've had the side cover off multiple times to replace stators) - just mildly curious...
Discussion Starter · #15 ·
My local Ducati shop had the parts. The mechanic said its a common issue and gave me an updated spring? I guess there was a recall on it. Gonna switch them out this evening. Got Threebond to reseal. The only symptoms I have is the bike likes to drop into neutral when shifting from 1st to 2nd and vice versa.
Yes you have same shifter. Can be symptom free or you may get a stuck shifter.
I had the experience that the change from sealant <-> gasket changes the position of the camshaft sensor aka pickup. Had to re-shim mine.
Got her cracked open. And it was indeed the return spring. My only problem now is properly adjusting the fork for smooth shifting. Is there a trick to it?
Prior discussion of topic and tool, best of luck.
1 - 19 of 19 Posts
