I'm wondering if the upgrade to the Nichols bolts for a 2000 ST2 is regarded as essential for preventing the dreaded crankcase halves cracking near the engine mount holes?
The reason I ask is I'm currently having Minneapolis Ducati replace the crankcase halves on this bike due to the aforementioned cracking of cases. A person in the owner chain of this bike at one time welded the cases but in a poor and questionable manner. I removed only a 1/16-1/8 inch of welded material past the casting to reveal the cracks indicating a surface weld without correctly beveling the cracks and filling them in with weld. Also the mount holes were never formed back to circular allowing a good amount of slop in the bolt movement. I'm thinking the engine mount bolt was never replaced either given its considerable bend. So now I'm having it done right.
I've been informed by both Ducati dealers in Mnpls that the 10mm bolts have nothing to do with the cause of this issue and that the Nichols bolts are not necessary. I was informed that the cracks were due to the bike being crashed at some point.
I'm not sure what to believe and I really do not want to experience this issue again. Are the Nichols bolts worth it or am I being overly concerned about this?
