21 - 23 of 23 Posts
They must have made the Neotec2 larger, primarily in the vertical dimension, because I can't fit my XL no matter what I try. All they need to do is recess the handle pocket less, it's the intrusion created by the handle/lock mechanism that causes the issue. Other than that I have zero problems with the sidecases, They are the perfect overall size, and are rugged enough for the job. Just that little tweak would take them from an 8/10 to perfect.
Well, that sucks. I was just about to pull the trigger on a Neotec 2 - Now I need to reassess that.
Just a thought... have you tried putting it in upside down?
My large Neotec 2 fits, but it has to be upside down and then it’s just barely. If the xl is a different shell size, I could totally believe no amount of fiddling would make it fit.
21 - 23 of 23 Posts
