Earlier Ducati bikes had Brembo clutch master cylinder pistons that were either 12 mm or 13 mm in diameter. Newer bikes such as the 1098, 1198, Monster S4S, Panigales, Diavels, Streetfighters, Hypermotards, etc. use a different radial pump design with 15 mm pistons.
Has anyone measured (or know) the diameter of the OEM slave cylinders being used with these 15 mm master cylinders?
