Interesting. Do you literally mean a Speed Bleeder or did you mean a generic bleed nipple?
Oh, my bad. Yes, any generic bleed nipple will do. I got hooked on Speed Bleeders and use them all the time. Pros and cons to them though. They are fast and easy, but they can seem to leak out a little. I haven't noticed air getting in, but have noticed a dab of fluid on the tips at times. Seems to be the nature of them.Interesting. Do you literally mean a Speed Bleeder or did you mean a generic bleed nipple?Sent from my iPhone using Tapatalk
Do you really need a nipple at every location to be able to bleed adequately?
What about reverse bleeding? I don't have a multi, but have found this method to be the quickest, easiest and most efficient option.
systems difficult to evacuate all the air of while using a conventional bleed method, were easily done by injecting brake fluid from the lowest bleed points.
Oh, my bad. Yes, any generic bleed nipple will do. I got hooked on Speed Bleeders and use them all the time. Pros and cons to them though. They are fast and easy, but they can seem to leak out a little. I haven't noticed air getting in, but have noticed a dab of fluid on the tips at times. Seems to be the nature of them.![]()
My Ducati tech installed a bleeder valve on my M1200R last year. Problem solved. Don't know why it's not factory installed.
They also offer nice dust caps to protect the bleeder.try Stahlbus for next time, they dont leak
That is great to see as it confirms my suspicion, and proves I'm not crazy. Oh sure, I'm crazy in other areas, but apparently not in adding a bleeder to the rear master cylinder.Yes. Here's a picture for you.
+1. No go here either.Tried reverse bleeding. Didn’t work, I’m assuming because of the ABS module. Couldn’t ever push any away from the caliper.
That is really good to know. I'd feel better not seeing any fluid on the speed bleeders.try Stahlbus for next time, they dont leak https://www.stahlbus-us.com/
I'm guessing it's not factory installed because of liability issues. The rear master cylinder is designed to be a simple, sealed, stout unit so it doesn't fail suddenly.My Ducati tech installed a bleeder valve on (the rear master cylinder of) my M1200R last year. Problem solved. Don't know why it's not factory installed.
1. It is on my bike, but I can't guarantee that for every Ducati model. See the specs for my bike in the link in Post #1.1. Is this the same thread size and pitch as the the abs module?
2. Did you put the bleeder on the caliper side or the reservoir side?
