Hi all, just added a +2 rear sprocket on my 749 (41 teeth, up from 39). When I went to replace the rear wheel, there was less chain slack due to the extra teeth and I couldn't line up the axel, so I had to move the chain tensioner collars forward significantly.
I've read in other posts that usually you don't need to add links to your chain if you're only going +2. I checked the chain tension and I have about 31mm of play at the mid point. I guess my question is: Does moving the rear wheel forward to accomodate the new sprocket affect the wheelbase/ handling of the bike overall?
New Sprocket
Chain Tensioner setting
Chain Slack- looks ok
New Sprocket
