I am offering a new tool to assist in the valve adjustment process for the 8 mm, 2V Motors only.
Rocker Holder Tool, designed to provide the leverage needed to easily hold down the closing rocker arm to remove half rings and change out closer shims. Made of 1018 steel in the USA. Will not damage face of rocker arm.
Used only on 8 mm valve stem motors, Pre 94, Belt Drive 2V motors, 907 Paso, Gran Canyon, MH 900e, Monster 600, 620, 750, 800, 800s, 900, S2R through 06'. ST2, Supersport 620, 750 up through 06' 800, 900.
Will not work on 7 mm, 2V bikes.
Cost $38.50
It was a big hit when I showed it at Ducstock last weekend.
Should be up on my website in a few days. If interested in getting on one, just email me.
thanks
Mike
Mike, I know this is an old post but do you still have this tool?
One tool now works for both the 2V -8mm (older Monsters, Supersports, etc.) and the newer (post 06') 2V-7 mm motors (monster 1100, DS 1000, Hypermotard, etc). A relief has been added near the end of the tool that fits under the valve spring to avoid interference with the valve spring that winds around the closing rocker arm on some 2V-7 mm motors. This relief was added to all inventory on 1/15/2015.
Mike
