I am now offering an new product. It is a Valve Holder Tool for 7 mm Valve Stems, used on Testestretta motors only. It consists of bent nose vice grips with two half cylinders welded on that when closed matches the diameter of the valve stem perfectly. The welded tip is made from mild steel so it wont scratch the valve stem.
With closing rocker depressed, the valve holder tool can be clamped onto the valve stem, thus holding the valve up making it easy to change out closer shims.
Fits the following bikes: 749, 998, 999, 848, 1098, 1198, Multistrada 4V, Diavel, Streetfighter, and 1199 Panigale.
First Pic shows the tool.
Second Pic shows it clamped onto a valve stem with closer shim assembled.
Third Pic shows it in use with the head cover removed.
Should be on my website in a few days, or email me if you would like one.
[email protected]
