I bought a new M1100 a little over a month ago and here is my issue.
The bike is hard to start after sitting over night or longer.
It is a cold start issue. When I go out to start the bike for the first time of the day it is very hard to start. Once the bike has been running I can shut it off and the next time it will start up fine. As long as it doesn't sit for somewhere around 8 hours it will start fine.
I talked with the dealer and he said when I bring it in for the 620mi and the Termi slipons, ECU, Filter it should correct the issue. He said it was probably because it was running lean.
Well I had the Termi's, ECU installed and I still have the same problem.
I took the bike back again yesterday to have it looked at. They reset the TPS and sent me on my way.
So I wake up today go out to the garage to see if it fixed the cold start issue. Nope... I still have the cold start issue.
Now this is what I have learned about this issue.
On a cold start... once I get the bike running as long as I don't take it for a ride or let it warm up... it can sit all night and it will start the fine next day.
So when I get it started if I shut it back down within 30 seconds the next day it will start fine.
If I take it for a ride... put it back in the garage... The next day it does not want to start.
Now I have to bring it back to the dealer for a third time. The dealer is not close and it is impossible for me to get there during the week unless I take a day off work. So next Saturday might be the next time I can get it in.
Is there anything I could check myself? Or is there anything I should tell the dealer to look for the next time I bring it in. Because they seem lost.
Thanks,
By the way... A cold start has nothing to do with the ambient temperature. And the battery is fully charged and turns over fine.
Thanks,
