1 - 10 of 10 Posts
Tried for awhile to find an affordable exhaust, came up with this. Bought some 12 inch universal mufflers. They fit great, sounds so much better than stock and shows off the swing arm!!!
that looks fantastic!
mind sharing where you sourced the mufflers?
Dime city cycles they have an online shop. I had to do a little grinding on the mufflers to make them fit. The mufflers were 1.5 inch exact so had to grind 4 lines to open the mouth to slide on and clamp em tight.
All in all cost me $220. Black exhaust wrap $55.
Discussion Starter · #9 ·
Thanks!
No fueling adjustments, it does not have the stock ecu, not sure if that makes a difference. A little bit of backfire dropping in low gears and high rpm but bikes always had that.
I'm sure this has been done on here before.
You may find that 20degree bend adapter pipes( I think the Triumph ones may fit but I'm not certain) make you end cans sit closer to the bike and will look neater overall.
I have a set of these cans in my garage and they are very loud, did you pack them at all as I think that does help tone the noise a bit.
1 - 10 of 10 Posts
