Whats the thickness of OEM discs on sports classics?
My Gt1000 has only done 27000ks and the discs already down to 3.75mm.
should be 4mm down to 3.6mm min.
stop braking so hard.
thanks.....Fitted some aftermarket brake pads early on which did improve braking and feel but maybe they are hard on discs!
the sintered pads can really get into them.
i see the most disc wear on m659 learners as a general rule. full throttle - full brake - full throttle - repeat.
Yep lots of commuting on the GT so I guess it is brake applications per mile not actual distance covered that counts.If they are only 4mm to start with I guess that wear is acceptable.
