1 - 8 of 8 Posts
I just finished installin a Bazzaz Z-FI, fired it up andit runs like crap. Sounds like its only fireing on one.
I didnt load any maps and my auto tuner hasnt arrived yet.
Is this to be expected? I figured it would have run at least as good as it did without it.
Thought the bazazz came with a map loaded in it? Not that it should make the bike run like crap. I would recheck your wiring as a starting point.
Ya i think i think it comes with a slip on map but i didnt load it.
I have a full pipe.
Pretty sure i got the wireing right, its very simple and straight forward.
So :
You installed a Bazzaz.
It should run with a default map or an auto tune.
You didnt load any map, and dont have the auto tune.
You're wondering why your bike run like crap ? seriously ? I mean, even before bothering checking wiring, you should maybe finish the install...
Upright Racer
Yeah you have to have some type of map loaded or have the autotune or it doesn't know what to do.
So a map needs to be installed. The Z-FI wont let it run the way it did before the install.
You think they would pre-load the factory map on it at the very least!
I mean its like it was instantly de-tuned.
Whatever...Hopefully the auto tune is here tomorrow.
Discussion Starter #7
Just For the record.....it should run somewhat normal when installing the Z FI even without the autotune.
It turns out that i had a a broken injector that was causing the poor running condition.
Thanks for the update bro, i had ordered one and then read your feedback... hope your running well now
1 - 8 of 8 Posts
