1 - 2 of 2 Posts
Never Grow Up
I bought a battery about 5 days ago, brought it home, poured the included 'water' into the cells and mounted it to the bike. I smeared the little packet of dialectic grease on both terminals and between the miscellaneous wires at each terminal. And threw the trickle charger on it. A few hours later it was reading 14 volts.
I left the tender on it as I've had it on the lift this whole time going through belts, oil, electrical, odds and end. So I took it for a little spin today before putting the plastics back on and noticed .... this.
The negative side looks fine.
But the positive side is fuzzy looking.
What the h*ll is going on with this?? Anyone have a thought? (I'm only a pseudo mechanic).
Vendor
Clean the dielectric grease off all the terminals and put it back on the charger.
See if the issue comes back again.
HTH
1 - 2 of 2 Posts
