OK, I've been chasing electrical gremlins since I bought my 2002 ST4S since I got it several months ago. It's coming very close to being tossed in the river with a brick tied around its neck. Anyway, I saw the post from another person that mentioned taking out the Evoluzione side stand bypass and I was going to do that and was playing around with the neutral switch that is located on the back of the transmission in a recessed hole. I tugged on it with moderate pressure and it popped off.
So my question is this, How tight should this connection be?
I can slide the connector back on the switch and can put some needle nose pliers to squeeze plastic connection around the switch but I don't know if that is adequate. If not then how do I get the switch/wire back in as a wrench won't fit down in there. Would it be worth changing out the switch entirely? If so I still don't understand how to install it with the wire on.
Heeeeelp!
Heeeeelp!
