Question... if you switch to something like the Nemesis or Microtec ECU, can you run pretty much any dash that shares the same plug as the "real" dash?
For example, could you swap an S4RS or 1098 display onto a 749, since there's no need for key/ecu matching?
I ask because I'm noticing that there's not really enough room for the 999 dash on my 748, so I was thinking of using a recent Monster or maybe a newer SB dash instead.
