You might want to check your info. The official release has not happen yet but it will in the next couple of weeks. Mark Just did a 1098r with microtec utilizing the dtc. The microtec ecu supports Ducati Factory Traction control. They will also release a stand a lone traction control for bikes that didn't come factory equipped with it. Read post number 8 in the link im posting. I realize that the microtec is a stand alone system. I mentioned it because the op asked about the nemesis which is also stand alone.Microtec is a full replacement ECU. It does NOT support or even retain the DDA or DTC.
They may be developing their own traction control system but it does not support Ducati systems.
Right now, today - they don't have any traction control available.
Ok. You win. We will see in a couple of weeks. I don't know if they have plans to support dda. If you have questions you can contact Mark at the ducshop since he just installed one of the microtec ecu's on a 1098R with DUCATI TRACTION CONTROL.still not buying it... The Microtec website does not indicate that Ducati Tracion Control is supported.
I doubt that it is - being that the Ducati ECU along with the traction control and the data acquisition software are removed from the bike when a Microtec ECU is installed.
Here is the Microtec website: http://www.microtec.cc/cms/en
If someone finds the info I'm missing please let me know.
Well Ducshop - please tell us more!
We are all impatiently waiting for a tunable solution for our ECU problems.
According to the Microtec website this thing doesn't exist but maybe you are ahead of the web updates - If so, please fill us in
Also don't forget - the 1098R has a completely different DTC than the streetfighter/1198...
This just strikes me as kinda funny - All those 1098Rs out there going into traction control mode around every corner should definitely be an EPA concern!!!it kills some of the fuel too so unspent fuel doesnt get into the atmophere for EPA reasons
I have a Nemesis installed on my SFS that's for a 1098. It's awesome! Fueling problems are completely gone. There are still some tweaks that need to be done with the speed sensor.Does anyone know if Competition Systems is developing the Nemesis ECU for the SF, and if so when it will be released?
Speed is ok it's just the odometer reads about 1.6 miles for every mile ridden. We've messed with the wheel size but then it throws off the speed. We think it compatibility issue with the computer in the dash since it's different than the 1098 computer. But like I said before we are adapting a 1098 ecu this is not an ecu built specifically for the Streetfighter. That side of it Mick has to work on, BMS just built all the mapping.What problems are you have'n w/ the speed sensor? No speed indication, too high, too low? Thanks
