Just an update on the current availability we have of ECUs and maps we can pre-load for you. We currently have all 3 ECUs in stock as well as the quick shifters, SBK mounts and USB adapters.
LIST OF MAPS
Hypermotard: ZARD slip-on map, Termi full system w/DP cams, Base map
Monster S2R800: Slip-on system map
Monster 1000DS '04: Base map
Monster 1000DS '03: Slip-on system map, Base map
Monster S4R: Slip-on system map
Monster S4RS: Full system w/open airbox and filter, Base map
Paul Smart: Base map
Supersport 1000DS: Slip-on system map
749R: Base map, Standard exhaust map
749RS: Full Race System map
749S: ZARD full system
848: Termi full system map, Akra full system map, Termi full system + HC pistons and head work map, Standard exhaust map
998: Slip-on system map
999S: 57mm Termi full system map
999R: 57mm Termi full system map
1098/S: Termi full system map, Termi slip-on map, Akra full system map, Standard exhaust map, ZARD full system map, Moto Corse full system map
1098R: Termi full system map, Akra full system map, Akra WSBK SPEC
LIST OF EQUIPMENT
Type 1 for 749,999, 848, 1098
Type 2 for Hypermotard, Monster 695, S4RS, SportClassic
Type 3 for SportClassic, Monster 1000, S4R, Supersport, 998, 996R
Reverse quick shifter for 749, 999, 848, 1098
848/1098 mounting bracket
Serial to USB adaptor
Development loom
Do you know who could do a custom dyno mapping of my 999 with a Nemesis? I am in northern Nevada.
