1 - 8 of 8 Posts
Hi All,
Have a track day tomorrow with the MTS1200 and am suppose to have all lights disabled or covered up on the bike. Checking the manual for the fuses I saw one labeled "lights" and figured if I pulled that one all of the lights would be disabled. I was wrong. With the #1 fuse pulled from the cockpit area, the brake lights, parking light (the led lights around the headlights) and the turn signals still light up. Checked manual again for front and rear fuse boxes and it is unclear what fuse(s) need to be pulled. Can anyone help?
I dont have a cct diag handy... But the indicators are driven directly from the ecu.. I dont recollect seeing them fuse protected...
Sent from my GT-I9100T using Motorcycle.com App
Ahhh.. Indicators come direct from dash ecu... No fuse..
Thanks for the response. Are "indicators" ozzie-speak for turn signals? If so, then there is no way to disable the turn signals by pulling a fuse, correct?
Anyone know how to disable the rear brake light and LED lights in the headlight area?
Rear indicators and tail light come from bbs ... No fuse...
Headlihts you can kill by pulling the relay in the front left compartment...
Indicators = turnsignals
#1 fuse in front fuse box is another wat to disable headlights.
The rear tail light and signal assembly comes off with 4 bolts and two connectors. I would just take it off.
Then tape up the front signals and headlights. Pull the headlight fuse.
1 - 8 of 8 Posts
