Hello all,
I'm in need of some help for my 2014 Ducati Streetfighter 848. It seems like no matter how many times I bleed the slave and master clutch cylinders of my bike, that it always accumulates some air after only a couple of days. I noticed this happening when I have difficulty putting the bike into neutral, as well as when I'm in stop and go traffic (which requires having to pull the clutch in and out several times). The problem I'm having is the clutch doesn't seem to disengage, even the lever is fully pulled in and the bike keeps moving forward. I've already had the lever adjusted to the furthest position after this latest bleed, but the issue just came back after a few stops and goes. Should I explore replacing the slave and/or master at this point?
