I checked the valve clearances this afternoon, and found some of them quite out of spec (0.05~0.25mm for the worst opening, 0.40mm for the largest closing)
Enough reason to adjust them.
So I removed the cams, have the opening shims out, and tried to measure the present thickness.
I however don't have the special Ducati shim-measuring tool, so did it with a thickness-micro meter.
The micrometer is slightly loose in the shim, it seems to be fine and measuring correct.
I also removed one of the closing shims, but there my problem starts.
I tried to find an alternative to measure these shims, but so far without a reliable result.
I can send the shims to Japan to have them checked and have them sending new ones, but I prefer to measure them myself first.
Any suggestions or smart ideas?
By the way, are Ducati shims going up per 0.01mm?
Eric
Eric
