Hey.
I need help with some bearing dimensions and specs.
1) The timing belt tensioner bearings.
The dimensions should be 12x32x10, correct?
I can get 6201.2RSH.C4 bearings.
Other option is 6201.2RSR.C3 by ***.
Which one would be more suitable?
2) Rear sprocket carrier bearings.
They should be 25x47x12, right?
3) Rear wheel bearings. Are they same as the sprocket carrier?
4) Front wheel bearings?
What specs etc?
I'm not really at home determining which bearings suit best.
Thanks a lot!
What specs etc?
Thanks a lot!
