1 - 7 of 7 Posts
Hey everybody, new memeber here. And a new Ducati owner as well. I've been riding my Suzuki GSXR600 for a few years now and now I made the leap and got into the Ducatis. I picked up a 08 Ducati 1098S in red. Now granted the bike has a bigger motor than the Jap inline 4. But my bike is shaking/vibrating pretty hard when riding and at idle. I feel like I'm riding a sewing machine. Also the exhaust sounds like a go cart, is this all normal? No one else rides ducati's around me so I have no other bikes to judge to see if mines a dud. And the acceleration isn't what I would expect either...Please help
RPM needs to be kept up above the 3500-4000 RPM range on most ducatis so you'll be riding in a lower gear than you're used to from an in-line 4. The ducatis are also generally geared too tall from the factory. Drop one tooth on your counter shaft sprocket and you'll be good to go. :)
As for acceleration, it all starts happening above 4000 RPM and hard core at 6000 RPM and above.
The harder it vibrates the more power you're making. You should really feel like you're riding a soil compactor. I'd say sewing machine is pretty weak. You should prolly get that checked out.
And the reason your exhaust sounds like a go-kart is because the ducati v-twin is actually made from two go-kart singles.
Troll.
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
Anything below 4000rpms and the bike feels like it's gonna fall apart. To cure this get a 520 conversion kit. This should more than fix that rumbling your not used to. Plus you will have that acceleration your used to on your gixxer, much quicker throttle response.
Trackday Junkie
Lol, you guys are funny!
Ak, the direct answer is that in order to make a high horsepower V-twin come anywhere even close to passing emissions laws, the motor needs to be severely de-tuned from the factory. Especially between idle-4k rpm.
You can ask your local Ducati dealership to adjust the bike to help out with the lean-fuel problem in that area. It helps, but in order to truly smooth is out, you need slip-ons, a Ducati Performance ECU, and a power commander to smooth out the mapping.
You can re-gear it, but personally I think the 1098/1198's are geared pretty perfectly from the factory. It's the fueling map that needs to be optimised.
1 - 7 of 7 Posts
