the engine keeps dying during decel in any gear with the clutch in or out. when i go to start it back up i have to cycle the start-stop switch before it will start back up. any help would be appreciated if you know of or have ever dealt with this issue. thanks in advance.
come to find out after finally getting ahold of a ducati superbike tech it is due to cam timing from the factory.
Indeed, Ducati have an "average to bad" cam timing out of factory.
749, especially 749S from 2005, were very sensitive to this issue.
You may want:
- A perfect cam timing
- A TPS reset
- Perhaps an idle rising (1200 tr/mn is good IMO)
- A fully charged battery (under 12.5V = get a new battery, good lead acid as Yuasa or a LifePO4 lithium one as Shorai, Skyrich, SPS etc etc)
- A perfectly working charging system.
My 2006 749s gives me same issue once in a while even everything is ok with everything else
