1 - 11 of 11 Posts
hi, guys
it's time to change a new battery.
Unfortunately, I can't take the hex bolt out from the battery holder(plastic in the middle from the picture)
So, there are any ways to fix this problem?
please...
Thank you so much
Tap a Torx/stardrive bit in there, the points will dig in and let you get the screw out, the tapping action will loosen the threads ;)
Or LH drills work like an ezy out, they turn anti clockwise.
Craig
Super Senior Poster
Hit it with Liquid Wrench or equivalent. The screw is an M6 x 25..just buy an extractor bit to fit. Sometimes just using a appropriate drill bit size in reverse will back it out or loosen it enough.
Don't mess with the big Ducati Dynamic D logo screw.....leave that be..
Discussion Starter #11
Got it!!
After spent 40$ for extractors spent half an hour searching on youtube "how to" and spent 2 hours for just one dam* hex screw.( my first time)
Ended up by using only drill to go all the way down to take the head off.(extractor doesn't work, dam* tight)
:), thank you everyone
1 - 11 of 11 Posts
