Need dimensions for fasteners for DR DESMO bar risers and foot peg lowering plates
1556 9
I have some DR Desmo 1" Bar risers and foot peg lowering plates for my 98 ST2, but,...no fasteners. Can someone tell me what I ned for each? Should I go with Stainless like Dr Desmo specs,...or would Grade 8 be a better choice?
Also,...Is there something that I need to relocate the brake light switch?
BC in Austin
1 - 10 of 10 Posts
Lowering foot pegs...
Howdy, pardner. I don't know how it will be on your 98 ST, but lowering the footpegs on my 2006 ST was a much bigger deal than I thought it would be.
Lowering the pegs was the easy part. Adjusting the foot controls was a nightmare because Ducati hadn't designed the linkage (on shifter OR brake) to accomodate. I had to replace my shift linkage with a rod from a 999 ($160); I adjusted the brake as much as I could (not much) and purchased another brake pedal with a moveable peg - it's still not perfect, but close enough that I can actually ride it safely.
I guess over there in Bologna everyone is exactly the same size and has exactly the same riding preferences...why bother to make anything adjustable? I bet the designers/engineers don't have erasers on their pencils, either. :confused:
BC in Austin
As for the the riser fastener size and length, remove one of your stock ones, measure it and get 4, 1 inch longer than you have.
Stainless will be fine or zinc plated 8.8
Can't help on the footpegs, I haven't heard of anyone succesfully doing this easily.
Craig
I've gotta laugh at myself a bit on that one..............thanks for explaining what should have been obvious Craig................."Doh!"
Craig
not so quick there cowboy
Hold up just a minute, on my 2003 ST4s that process wont work with my 1 inch bar risers.
The DR Desmo has a 7.5 degree swept back position that I am forced to use because the std position causes interference with the fairing, no bending the brackets that hold the brake and clutch fluid master cylinders does not suffice.
so to use the 7.5 degree position requires (2) 25 mm and (1) 40 mm bolt for each side.
I'm glad it's not just me. I figured I was doing something wrong as they were on the bike when I got it and it wasn't obvious that what I did was the right way to reduce the sweep. So it is just swap L to R and turn over, then?
Discussion Starter · #8 ·
I have seen that pic. Its actually why I posted my query, because the risers I have dont look like that pic. They have a note at the bottom of that pic that "actual item may vary from pic". Guess I have to take a pic of mine and post it.
In this photo they show 4 bolts the same size and a basic spacer?
http://www.drdesmo.com/st24rise.htm
Craig
[/url]Craig
In that photo (my risers are different) they are showing the two bolts for each side that attach the handlebars to the risers,
They're not showing the stock ones that bolt from the triple clamp to the risers.
I believe that is correct. I had mine flipped, cheucked, torgued and cursed.
The std position was not working, forcing the 7.5 degree sweepback.
My risers have 3 holes each, the one on the paperwork I got with it had about 6 on each riser, looking at the accomping paperwork made no sense.
1 - 10 of 10 Posts
