The clip that holds my wiring harness in the display broke off. Anyone have an idea on how to keep the wiring attached without replacing the entire harness?
Can you post a picture so that we have some idea of what the problem area looks like?The clip that holds my wiring harness in the display broke off. Anyone have an idea on how to keep the wiring attached without replacing the entire harness?
Duct tape. Lol.Duct tape will fix anything
On a more serious note, usually you can just replace the connector. The pins pop out and can be put into a new housing.
Ducati Wiring Connectors
I don't know if they carry what you are looking for, but it is worth a shot.
The world can be saved with duct tape.Duct tape. Lol.
Sent from my SAMSUNG-SGH-I727 using Motorcycle.com Free App
I think that this is the fix that is going to work.Tiny holes with the dremel and micro zip ties work miracles in these situations.
That or you can do it the right way and replace the connector![]()
Duct tape and WD-40...Duct tape. Lol.
I just did exactly what I described to a connector on my Husky. Worked out fine on a vibrating single cylinder.I think that this is the fix that is going to work.
