Talk to the guys at orient express and get some Ktech cartridges
, and it will be cheaper doing it one time , it’s the tru fix
How is it these forks can't be rebuilt? Looks like a pretty easy job to open them up, removing rebound piston and compression shim stack holder.It’s just the K tech internals you get to keep the black chrome sliders and the black anodized fork tubes. The only way you know that K tech is in there from the top fork caps.
It is the only solution because the OEM cartridges cannot be rebuilt that has been discussed before on this forum
I've read so much negative reviews on those cartridges. I don't think think they are any better then the Marzocchi internals.![]()
ANDREANI FORK HYDRAULIC CARTRIDGE DUCATI HYPERMOTARD 1100 SP EVO 2007-12 | eBay
Find many great new & used options and get the best deals for ANDREANI FORK HYDRAULIC CARTRIDGE DUCATI HYPERMOTARD 1100 SP EVO 2007-12 at the best online prices at eBay! Free shipping for many products!www.ebay.com
IDK, the multistrada weighs at least 100lbs more than a hyper and it has stiffer springs to accommodate somewhat for gear/passenger/bags. I'm guessing the springs are too stiff and the valving to control them is anyone's guess.@polyesterpig yeah, stock setup on the tripples
@fastgas I don’t think the springs are way too soft, and the valving is easy to modify. I’ll try with the stock setup first, we’ll se where it goes from there.
hypermotard is a bit lighter, so I guess the valving is okey for my use. I might opt for 70mm/N springs.
I’ve got the manual comp and reb adjusters from WRS
