Need advice on fixing bolt threads again.
OK I've mentioned this before but I messed up the threads on the little bolt hole underneath the mesh filter. The little plug sorta you never mess with. Anyway I had the guy who sold my track bike to me look at my 996 to see if he could fix it. Here's what he said. What should I do here?
"Threads are definately stripped and only one good thread exists at the top of the hole but the bolt doesn't contact this thread. It leaked a good bit of oil over the last couple of days as well!
Anyway, not an easy fix as the bolt is not a standard size at 15mm with 1mm pitch.
The only option I can think of is to drill the hole out, tap to a larger size standard bolt, install new bolt and seal with permanent thread sealant.
Due to the size of the bolt required, all the components will be costly. A standard hex head bolt will not work due to the limited work space. A socket cap bolt is the best option and even this will need to be machined down to fit the machined opening where the crush washer sits.
The bolt (stainless), drill bit and tap will be roughly $60 and machining the bolt head will be roughly $40. I've got about an hour into it already and figure it will take about another hour and a half to finish it off once I get the parts. Your looking at roughly $200 for the fix. I know its high but this isn't an easy fix like I thought it would be."
