Hello All,
I’m in the process of putting my bike back together. The bike is 2002 748S/855, I was wondering if anybody has run a 15/41 sprocket setup.
I just receive my AFAM 41T rear sprocket with carrier. Should I also change out my 14t stock AFAM sprocket?
15/41 is the exact same thing as 14/38 so you would be netting a zero difference over the oem set up...which is geared too tall to begin with.
i run a 14/41 in my 853r and like it for our local tracks and twisties but 14/40 would probably be a better choice considering the improved torque curve of the 85x upgrade.
Super Moderator
I have 14/40 on my 748SP and that is about right, since i do twisties and trackdays. I would like to have the 14/41 option (since I´m still at 748cc), but 14/40 works well.
I´d go 14/39 or 14/40, depending on how you ride. That would be something like ~15/44 if you really want to stay with a 15 F sprocket..
855 Sprocket
I will try the 14/41 at my local track this spring ( Loudon). I guess i will look up 40t for my rear. 14/40 .. Thanks guys,
