1 - 3 of 3 Posts
Hi everyone. I want to remove the MPH dial on my speedometer and replace it with a KPH one.
Can someone tell me how to remove the sweep hand/needle which has to come off before the dial can be removed :confused::confused:
Thanks
Discussion Starter · #2 ·
Success !
Hairdryer to put some heat into the needle hub, two-spoons method as in the video :-
except desert and not tea spoons and pressed more on the spoon bit and not handles. First I cut a cardboard (cornflakes box) protection and loosely tethered the needle with some scotch so it didn't go to the dark side of the moon when it came off, like things always seem to do...
The spoon method works, together with the heat tip from "newtacho" who makes up new displays.
:smile2:
1 - 3 of 3 Posts
