I have molested the MTS harness (It's nice to have an extra harness to practice on), and cracked open the ECU-connectors. I tried to pry out a few of the terminals with a steel wire of the appropriate size, but it would not move. I tried my luck and pulled two terminals from the harness side of the connector. Sure enough they came out, but they will not click back into the ECU-connector. The terminal retainer drawer will hold them in place (the yellow drawer), but I want them to click back in. I have to figure this out. They should be removable. There is only a few of the ECU terminals that I have to move, so this is no big deal. I'll look into it this weekend. Worst case, I have to buy a few new terminals.
The plug for my dash-support is done, I just need to let the epoxy fully cure before I can continue. I hope this one turns out OK.
And, I switched from the non-linear to linear TPS taken off a Fiat. I took my time to clean up the throttle bodies. I will do a TPS reset with a little twist. When I've got the ECU up and running, I'll back off the throttle stops and balance screw, reset the TPS (electronically), adjust the stop screw so that the ECU reads twice the opening, then do another TPS reset. The TBs are set at 2.4 degrees and balanced there. I think it will be a little higher depending on the reset value of the ECU and BIN I'm using. I might have to to a TB balance later, but that's okey. I hope this will not ruin my low end tuning too much. I'm interpolating my 15M map, that Punch helped me with, to convert it into a 5AM map. I've heard there might me a fixed factor I have to multiply my map to get the right values. More on that later.
And, UKSteve helped me with the values of the MTS fuel level sensor. It's 10k ohms at full and 100k at empty. I might use a 22k 1/4 watt resistor to fake an almost full tank of fuel - This will us a little less current compared to the 10k resistor.
Update: The terminals have to be oriented the correct way to re-click in. Now I just have to figure out the best way to remove them. I'll practice some more on the MTS harness before I start on the SS1000 harness I will actually use.
