Organize the feeler blades:
Summary of the readings (shims and clearances):
In the meantime, let me build a sturdy support for the dial indicator to precisely find TDC and measure valve lift (needed later on to dial the cams).
This is the "hook" that sits on top of the closing shim to measure lift:
Testing the measuring
Details of the support bracket:
As I mentioned elsewhere I discovered that one of my rocker was worn and the chrome plating has came off:
More to come in a couple of weeks when I'll be replacing the rocker, installing MPB retainers and shims, and probably start the cam dialing...
