1 - 20 of 20 Posts
Hey guys,
I previously had a 02 998 biposto which I sold to my brother. While I restore my 888, I was scouring craigslist for a project and came across this 01 996 in NC. I immediately noticed the ohlins front forks, what appeared to be a 3 piece airbox of sort and a larger Silmoto exhaust. After talking to the seller, a deal was struck and I made plans to make the trip from the Tampa area to NC to pick it up. After a 10hr drive, the bike was just as described. It fired right up and the seller had the belts recently replaced. The fuel quick disconnects were replaced with all metal and the exhaust was measured and confirmed to be the full 54mm Silmoto system. The airbox is a 3 piece design, but not 100% carbon. The fairings are aftermarket fiberglass with a bellypan which will be listed for sale. When I pulled the tank to check the fuel disconnects, the inner fuel injectors were unplugged as part of the single injector chip modification.
The plan is to go through the bike and clean/replace/rebuild whatever is necessary to make it a semi-oem resto. The tail will have to be replaced as a large hole was drilled on both sides to install the hideous rear blinkers.
I'll be updating this thread as progress is made. Thanks guys and any help/input/advice is always appreciated!
Jared
As you say, ditch the glass faring. Airbox is a WSBK replica. If it fits and looks ok then leave it. From the pics it looks to be a tidy bike.:) Will be interesting to see what's under the panels.
J, check your PM's...I've got some OEM fairings.
Congrats on the find!!! Please take pics of your progress. I'd love to follow along.
Discussion Starter · #9 ·
Not too much of an update but it's something. Been busy with my 675R track bike and 888 restoration. I was able to mount the Ecu in the proper spot on the mono subframe and got the harness to fit without much fuss. Other than that, I did an oil change, put in a motobatt battery and took it out for a 100+ mile ride when we actually had some fall like weather. Still deciding what to do with the fairings.
Jared
How did you like it on your ride?
Nice find with all the goodies.
Do you have a thread for your 888 rebuild? I would be interested to see that.
Discussion Starter · #14 ·
Been enjoying the bike and took it for a ride yesterday. Decided to give her a bath and chain cleaning/lube. This morning I noticed the fuel pump would continually prime with the key on. Checked relays, wiring, tank wiring/lines etc. After some research, it seems like the consensus is a bad eprom. I have another single injector eprom coming in to test. Anyone have more insight about this? The bike was running great yesterday.
Bike is lookin great. I like the cop car in the back ground, do they just wait for you to pull out of your drive? >:)
Sorry, I have no input about the eprom but I'm sure someone will chime in
Have you lowered the rear purposely or did you get her that way?
Discussion Starter · #17 ·
Considering its my cruiser, I usually don't have to worry about tickets >:)
Nice! Just picked up a 01 996 myself love these bikes! IMHO the best looking Duc Superbikes ever!
Well that explains it, you sound like a good friend to have :nerd: If you ever get up here on some curvy roads hit me up, sounds like you have some cool bikes in addition to this one
1 - 20 of 20 Posts
