Well, after sitting with Marvel Mytery oil in the cylinder for almost 2 weeks, the rings broke loose! :) For the first time in 38 years, she turned!
Threw a compression gauge on it and kicked her a few times. 145 lbs.
I think she's a runner folks!
Next order of bidnes: Check points, put 6v coil on, get intake manifold and go through the carb, change oil.
Discussion Starter · #2 ·
Uh Oh
The shoe has dropped....maybe. Need to figure out how i'm going to go about this...went to pull the carb off and just as I start to turn the nut, two pieces fall off the head....Me thinks i'm starting to see why it was parked.
That can be fixed... I have no idea how much it would cost, but it can be welded up. Or you can start the search for a new head. They're out there.
This morning I had a "momment of clarity" and realized that a friend I race with has a welding business. Sometimes I scare myself.
BTW, what spark plug do these take? It has an old British KLG plug right now.
