BMW helmet lock rekeyed to fit my Ducati ignition key.
The bracket itself is made of 1/8 aluminum. The two bolts that support the exhaust from underneath (heads are just under the edge of the rear of the gas tank) are replaced with slightly longer SS allan head bolts. The plate bolts under the exhaust (with SS locking nuts) and extends out to the left side of the bike... The BMW lock assembly was re-keyed to fit the Duc and bolts to the bracket, also with SS hardware.....
Scott
The helmet lock body itself should be:You wouldn't happen to have the BMW lock, part number, would you?
