1 - 20 of 39 Posts
Well, I've built and restored bikes for a very long time. I always hope that someone gets some useful information and ideas so that they can use on their own builds. Hopefully motivate someone to tackle that project. This was a frame off rebuild and if you want details I can post the start to finish process?
Here is the before:
1005587
and After Pics
1005588
Discussion Starter · #2 ·
Here are pics of the tear down. One thing I make sure before I take it apart is the bike and all its systems are functioning properly. I fix any wiring issues and also make sure all lights work and the bikes charging system is up to the task.
1005591
1005592
1005590
Here's some work on the engine. All cleaned up and polished up ready for paint.
I didn't want to separate the cases as there were no leaks. I found a close match to the engine side cases and engine color. I also was building this for a track bike and I also put my custom and artistic twist on what I would have done if I was at Ducati.
1005594
1005595
1005596
1005597
1005598
1005599
1005600
I didn't
1005593
Here are some misc part being refurbished, headlight assembly, radiator, swingarm, steering head, some plastics.
1005601
1005602
1005603
1005604
1005605
1005606
1005607
1005608
1005609
Discussion Starter · #5 · (Edited)
Here's some more of the stock exhaust cleaned up and made to look heated in. Used a stainless wire wheel to polish then a MAP gas torch to petina the colors I wanted. I also gutted and made a proper slip on out of the stock pipe with 2" perforated stainless baffle using the inner end caps of the orig baffles. I welded the perf tubing to them then secured with stainless pop rivets. I also painted the stock can a matte dark grey metallic. They sound the part and performed flawlessly.
1005620
1005621
1005622
1005623
1005624
1005625
1005626
Discussion Starter · #6 ·
Exhaust
1005630
1005631
1005632
1005633
1005634
1005635
1005636
1005637
1005638
1005639
Discussion Starter · #7 ·
Here is the frame going together
1005640
1005641
1005642
1005643
1005644
1005645
1005646
Discussion Starter · #8 ·
Here's the bodywork going on. I went with iFairings (ZXMT) with a Troy Bayliss paint job. For the money these are a great deal and are almost as heavy as the original fairings. I'm a painter and was pleased with the quality. I painted a spare tank to match the INFO STRADA Themes.
1005647
1005648
1005649
1005650
1005651
1005652
1005653
1005654
1005655
1005656
Reactions: araitim and LA2SD
Discussion Starter · #9 ·
Part 2 on the paint.
1005657
1005658
1005659
1005660
Discussion Starter · #10 ·
Finished bike and some track day pics.
1005661
1005662
1005663
1005665
1005666
1005667
Discussion Starter · #11 ·
Barber Motorsport Park Track Day March 27th with STT. Great time, the bike worked flawless. Managed to get the suspension dialed in and it was a blast. Oh by the way, I'm 60 years old and have loved every minute of motorcycling and won't stop as long as my body and brain can do it!
1005668
1005669
1005670
1005671
1005672
Fantastic! Excellent, this is amazing.
I've always wished I could paint well. Looks like a very well done job and looks like you're enjoying it :)
View attachment 1005668 View attachment 1005669 View attachment 1005670 View attachment 1005671 View attachment 1005672
This is one of the best resto blogs I have read in a looooong time.
Awesome result and thanks so much for sharing!!!
Wow, great job, very detailed. Love the Infostrada look, my favorite race colours. As another (almost) 60 y.o good to see you out there riding as well.
Amazing build, congratulations!!
Can you share the paint coded that you used to spray the engine and parts with the dark magnesium look? I'm looking to do the same to my 999 next winter but its difficult to find good color match for the gold magnesium look.
The one you used seems to be closer to the magnesium color that Honda normally uses. Ducati seem to have a mag that is closer to gold than bronze.
Incredible!
Two questions:
1) Why the screws in the lower triple? I assume you want to limit the steering range for some reason?
2) Where do you get the vinyl to shoot the letters etc?
1 - 20 of 39 Posts
