While riding tonight, the temp averaged 260 degrees F with the ambient air temp around 72 F. Does that seem high? What kind of temps are you guys seeing under similar conditions. I was cruising about 50 mph on a flat road.
My friend who has a LV midpipe and exhaust was consistently 40 degrees cooler. I think he also has the Ducati race ECU. Perhaps the ECU is dumping more fuel in the <5000 rpm range. Can the catalytic converter create that much additional engine heat?
Don
Don
