MW Tuning Low Temp Fan Switch: Ducati 748, 916, & 996
$69.95
The correct fan switch to lower the operating temperature of your Ducati.
*OEM: Fan turns on at 197°, fans turns off at 188°
*MW Tuning Switch: Fan turns on at 179°, fan turns off at 152°
The idea with this switch is to keep your fan on as much as possible in the normal operating range to ensure no chance of over heating, but unlike manual fan switches this will ensure your fan is always turned off when the bike is off.
This kit includes the switch, new crush gasket, and 2 spade fittings.
This kit will require you to clip off the OEM plug, strip the wire, and crimp the wire into the new spade fittings.
Switch is made in Italy
Keep your engine cool and protected with Motul Engine Coolant and Additives
MOTUL MotoCool Coolant
$9.95
A ready to use cooling liquid, antifreeze and anti-corrosion for bikes cooling systems.
•No mixing necessary
•Avoid engine overheating with its high boiling point 133°C/271°F
MOTUL MoCool additive
$15.95
Top concentrated engine cooling additive that works in any cooling system of bikes, cars, ATVs.
•Reduce engine temperature by 15°C (30°F)
•Outstanding thermal exchange
•Anti-corrosion
* Outside continental USA, use shipping coupon codes:
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
